i've got abit stuck stuck with the remove of the front bumper
i've got the headlights abd indircators removed also the front grille. ooh and the air filter box, but for the life of me cant find the 2 nuts ref'd in the haynes which hold the bumper on, anyone got any idea's or even better pictures please ?
Front bumper removal ?
Re: Front bumper removal ?
theres 2 8mm nuts inside the wheel wells at the bottom, usually covered in crud.
As for the 2 bolts under the headlights, under the airbox there is a black plastic over your need pop out, that should reveal one, then just look at about the same place on the opposite chassis leg and remove that bolt too.
I'll try get pictures over the weekend.
i got the two 8mms in the wheel wells (just on were the black trim starts?) i've got the lil plastic mat type thing off in the air box area, but still strungleing to see anything, but its dark now and the strip lamp in the arch aint so hot so, i'll take a fresh look in the morning.
Thanks again envoy.
Mark.
Thanks again envoy.
Mark.
no problem, all will become clear soon i think.
i appear to have had a dumb day on saturday, i found the nuts in question . . . Doh!
hi im having the problem removing the front bumper iv managed to remove the two bottom scews but on the air box theres a pipe going off the air box and into the bumper is the main bolt behind it als how do i remove the pipe thanks
