Wet carpets
Wet carpets
Hi all, Both drivers and passengers side front carpets are soaking wet. I`ve blown out the sunroof drains with an airline. I`m pretty sure its not the door seals and cant see any problems underneath. Its only wet right in the bottom though, any ideas?
Re: Wet carpets
check the drainage of where the wipers sit, also check the trunking at the back of the bay near the rack
Re: Wet carpets
Cheers Gaz i`ll give that a try, i`m getting fed up with misty windows
Re: Wet carpets
Usually down to a perished seal under the wipers as above. Theres a thread in the How2 section about this particular problem too
- himselfunknown
Re: Wet carpets
9 times out of 10 it's the 'elephant trunk' blocked. This is about midway along the bulhead about 6" down from the wiper scuttle panel. It fills with crap, and water backs up through the heater.
Re: Wet carpets
Cheers guys, I`ll have a look at it tomorrow.
