Hello
Recently my seatbelt will not lock in at all, sometimes is does clip in but as soon as I breathe out it just unclips.
I’ve found a work around, I just plug it into the passenger side. Which I don’t think is entirely legal or safe. If I have a passenger on board then I don’t have a seat belt at all.
So does anyone know a fix or can I use any different Vauxhall model seatbelts?
Thanks
Seatbelt clip
Re: Seatbelt clip
It sounds like it is the socket part that is sticking or gummed up.
Have you tried squirting a bit of Carburettor cleaner, Plus Gas or WD40 into the socket part to loosen or soften whatever is jamming up the mechanism.
The problem that you may have, is that the seat belt socket is part of a large pyrotechnic retractor mechanism.
So -
1 - do not wallop the socket to shake the insides loose. (Unless you fit the red anti-trigger piece onto the end of the retractor tube).
2 - it is a difficult part to get, as it cannot be posted - again due to the explosive mechanism.
3 - it is quite a large part that is specific to the Cavalier and Calibra.
You can carefully prize the covers off the buckle to get better access to clean the mechanism.
So -
Re: Seatbelt clip
If you have a model without seat belt pre-tensioners, you don't need to worry about any explosive parts.
If you can find a scrappers or a breakers yard somewhere and they have a car or two in there, worth just going there and getting hold of a second hand replacement, chances are it'll work. Can always test it while you're there.
Re: Seatbelt clip
Thanks for the replies!
I feel like a right plonker right now, I’m sat here thinking “explosives in seatbelts!? Naaaaaah” but after thinking about it and YouTubing I have learnt what you guys are on about.
It’s a 95 ‘classic’ cavalier. Anyone know if that has the explosive jobbies? Because that sounds well out of league for fixing lol
Cheers again boys
Cheers again boys
Re: Seatbelt clip
I suspect all Cavaliers after 1993 will have the "explosive" retracting belts.
So yes, yours should have them.
A big black cylinder along the outer edge of the underside of each front seat.
Connected by a long brown sleeved retractor cable sheath.
To the base of the seat belt socket.
The socket should have a concertina style rubber bellows immediately below the buckle socket.
In all honesty, you need a decent shock wave to trigger the retractor.
Like whacking the cylinder with a big hammer.
What you want to do is simply clean and lubricate the buckle socket thingy.
Just a matter of NOT whacking anything near the seat to vibrate the buckle mechanism loose.
My buckle played up a few years ago, due to being gunked up with restoration muck and dust.
It has worked itself loose over time.
So always works fine now.
There can only be two things wrong with yours.
Clogged / jammed / seized up due to muck and dust.
Or
The internal sprung latch of the buckle is worn / broken.
If it is broken, then full replacement is the only possible fix
Or
Re: Seatbelt clip
As said, it probably just needs a good clean, a method that's worked for me too.Robsey wrote:It sounds like it is the socket part that is sticking or gummed up.
Don't worry too much about the dramatic sounding explosive seat belt pre-tensioners, it sounds more daunting than it is.
The red anti-trigger piece Robsey mentioned is attached near the end of the cylinder, tucked out of sight.
You just slot it in the end to lock the tube, I think this is covered in the Haynes manual, the next best thing to a forum
Re: Seatbelt clip
Thanks for all the advice, really appreciate it.
I’ve sprayed some wd40 in it so will see how we get on
Thanks again
Thanks again
Re: Seatbelt clip
Being as they are facing up they tend to pickup more than their fair share of crud, might be worth giving it a good blast with an airline.
