hi all. there might be an answer to this on here somewhere but i'm struggling to find it... does anyone know what bits i will need from a donor cav gsi/turbo if i want to take the headlamp wipers/washers and fit them to my cdx? i'm interested to know which bits i will need and how best to fit them?
thanks in advance for your help
headlamp wipers and jets from gsi/turbo into other cav
Re: headlamp wipers and jets from gsi/turbo into other cav
Need:
Wipers
Motors
Wiring
Washerfluid bottle (or you will be forever filling it up)
Tubing for fluid
And relays and a books of words to work out the wiring
Wipers
Motors
Wiring
Tubing for fluid
it is quite involved
Getting everything lined up on the panel would be my concern, wiring is a doddle if you just take the time to revise your plans and work around unforeseen problems
i dont follow. which panel do you mean, the panel under the headlamp? which problems do you forsee?!Envoy CDX wrote:Getting everything lined up on the panel would be my concern, wiring is a doddle if you just take the time to revise your plans and work around unforeseen problems
You will need to get it lined up to get the holes drilled in. ! hole for the wipers and another for the washers. You can use double sided trim tape for the rubber bits the wipers rest on. I reckon that will be the trickiest bit
Yes, the panel you'll have to drill through to put the motors in and wiper arms on.ilovemyelite wrote:i dont follow. which panel do you mean, the panel under the headlamp? which problems do you forsee?!Envoy CDX wrote:Getting everything lined up on the panel would be my concern, wiring is a doddle if you just take the time to revise your plans and work around unforeseen problems
I'd make a template from the car you take them off personally.
