Alloy wheel paint code
Joner1983
Post by Joner1983 »
Hello all
I'm planning on respraying my centre caps as they've started to peel. Want them to look their best ready for Retrorides in a couple of weeks. Any idea what the paint code is for standard Cavalier alloys? I've got fan blades on my V6, same as facelift SRi but 5 stud. Cheers
1991 H White 1.6L
1992 K Burgandy 1.6L
1989 F Lt Blue 2.0 CDI
1992 J Spectral Blue GSI2000
1995 M Black 2.0 SRI 16v Eco
1995 N Grey 1.8 GLS
1990 G Met. Red 2.0 SRi 20seh
1994 L Grey 2.5 V6
1992 J White GSI2000
So far...............
Re: Alloy wheel paint code
I have looked around a few Vx forums regarding this issue.
The issue appears to be if you apply clear lacquer afterwards, as this can add a slightly darker hue to the silver.
In order of preference:-
Star Silver... (No lacquer).
Astro Silver if adding lacquer coats.
Rover Silver Leaf also goes well if lacquered.
Several posts / forums recommend the Hycote brand of paint and lacquer for the nearest colour match and final finish.
Joner1983
Post by Joner1983 »
Amazing, thanks. Do you know which star silver it is? I think there's 3?
When I sprayed my front lower panel I noticed my new grey paint looked darker after I lacquered it. Assumed it was just that the original grey had faded so the new paint looked dark
1991 H White 1.6L
1995 N Grey 1.8 GLS
1994 L Grey 2.5 V6
Link:
https://www.mk3oc.com/forum/threads/def ... here.7158/
88L, star silver 1 met (91-97) will be the original, the other two are later.
Yep - according to my list of POC codes.
Only Star Silver - L88 / 138 was available at the time of the Cavalier.
I have seen 138 mentioned many times in other forums' threads.
Joner1983
Post by Joner1983 »
Amazing, cheers guys. I'll get some today and let you know how it goes 🤞🏻
1991 H White 1.6L
1995 N Grey 1.8 GLS
1994 L Grey 2.5 V6
I painted mine Star Silver and lacquered them after and thought they looked 'right'? (don't know what code though)
Joner1983
Post by Joner1983 »
I had a go with star silver 1 and after a few coats it definitely looks darker than my originals and has a lot more metalic in it. Could be my wheel have just faded a lot? Forgive me if this is a stupid suggestion but I wonder if it's worth doing another centre cap with a white primer instead of grey and seeing if the silver finishes lighter??
1991 H White 1.6L
1995 N Grey 1.8 GLS
1994 L Grey 2.5 V6
It shouldn't make any difference, unles you are only doing thin mist coats over the white.
