slam panel
slam panel
bit of a sanity check as i dont have mister haynes to hand, but on the mk3 cavalier is the slam panel bolt-on or is it spot-welded on?
ta
Re: slam panel
welded unless its been smashed off i wouldn't be replacing it as its a sod to get it sitting perfect as it effects all the front end even if its slightly off.
Re: slam panel
It's spot welded as said above :)
torsion
Re: slam panel
Post by torsion »
Spot Welded on,I have recently have changed it on my calibra hovever you have to be very very careful...All front end could look terrible when done poorly.....You do have 4 point punto welds.
Cars I run
-Vectra GL 2.0 8v 93
-Vectra GT C20XE 93
-Calibra C20XE SE1 pack 93
