seatbelt clip
piercedrab
seatbelt clip
Post by piercedrab »
ok here goes the seatbelt clip that is attached to the drivers seat isnt working and some times the clip will go in from the belt and other times it work ive had a look and the retainer keeps moving what i was wondering is can you replace the whole bit or is it attached to teh seat with a bolt i could remove it and stick another on
Rage
Re: seatbelt clip
Post by Rage »
Can't remember how its attached but i know its attatched to the subframe/ seat rails i had the same problem with my mk3 astra and i just swapped the subframe
Re: seatbelt clip
Is attached to the pretensioner system which requires removal of the seat/subframe to swap
piercedrab
Re: seatbelt clip
is there an alternative replacment that doesnt require the tensioner
Re: seatbelt clip
No, just change it, its a simple job that can be done in half an hour with a basic socket set
piercedrab
Re: seatbelt clip
kl cheers mate just need to find a cheep replacment now
