always on the eye out for better seats than my cdx leather, so what other models fit?
I would like vectra sri half leather seats as they are cheap and often available - and very good looking seats. As an example, would these fit?
What other models's seats will fit???
Re: What other models's seats will fit???
vectra seats will fit but you will need to modify them, you need to modify the front runners, the backs don't need too much work done to fit, I would leave your CDX leather, change the front seats for cavalier turbo ones so they hold you in better.
ignore me its a no. found a thread on migweb from someone else. bugger.
yes mate its finding cav turbo seats and for £100 or so. there is a set at my local scrappy but the drivers bolster is torn and I dont want to spend too much fixing it. I assume its a pig to sort.cavalier3822 wrote:vectra seats will fit but you will need to modify them, you need to modify the front runners, the backs don't need too much work done to fit, I would leave your CDX leather, change the front seats for cavalier turbo ones so they hold you in better.
i got mk2 astra connelly leathers in mine fit straight on the runners
think you can pritty much foit any vauxhall seat in buddy
They will fit stoater85 ! I have seen a mk3 cavalier with the exact f+r seats your talking about! I would of thought if the vectra subframe don't fit the cav's floor pan then you should be able to fit the cav frames to the vectra seats anything is possible if it weren't for the fact that my front seats are so good for 174k on the clock as I want the vectra b rear seat so I can have rear headrests and the 3 point seatbelt in the middle!!!
[center]
