C20XE ON WEBER 45's
C20XE ON WEBER 45's
Hi folks i'm new 2 this site but had cavi's for a few years now..........
Has any 1 put weber 45's on a xe if so wot do i need 2 change or has any 1 got a link/guide they can point me in the direction of basically need a pic or guide of the wiring set up for starter alt dizzy etc. cheers
Re: C20XE ON WEBER 45's
how do you want to do it cheap as possible?
http://www.h-h-ignitionsolutions.co.uk/index.htm do a replacement dizzy kit.
starter and alternator are a separate curcuit, just leave them be. and remove the engine loom.
well bassically iv got the carbs reg pump everything except the dizzy wot i bought came off a xe but i never seen it. but if ur sayin the starter/alt is a different loom then should b easy enough
so that means no ecu??
1.4 l
1.8 gls hatch & x2 saloon
2.0 cdi pre face lift
2.0 dippy pre face lift & 2 face lift
2.0 gls 16v
1.7 TD gls
2.0 sri 130 seh x2
2.0 sri 115 ne saloon
2.5 v6 auto hatch
2.5 v6 cesero
2.0 gls 16v
1.7 TD gls
2.0 sri 130 seh x2
2.5 v6 auto hatch
2.5 v6 cesero
nope no ecu its done off the drive in the cam to time the spark.
How are you doing the fuelling have you replaced the pump as the multipoint will overfuel the carbs
got facet pump for it. doing away wif pump in tank
your going to need to make a new feed to the pump as your gonna remove the fuel pump relay.
way i would do it would be.
use a 4 pin relay, and a fairly deacent feed off the battery to the relay and then to the pump
other side of the relay -either use a switch on the dash attached to a switched live,
or directly to a switched live
(depends if you want the pump on a switch or just on with the ignition)
Id put it on a switch myself so you don't have it running when you don't have to, as they dont like running dry and burn out very quickly.
i'll give that a go. sounds easy enough
