Guys,
I have to rebuild the exhaust system on the Cav and as a mate has access to ramps we are going to do it in his workshop but he has asked I get the Clamps and Gaskets and have no idea how many I will need.
I am presuming there is a gasket between the 2 parts of the manifold, one pre cat and one after then one at backbox??
May as well replace all the hangers at the same time so what do I need? and best place to get them at reasonable cost as Halfrauds is bloody useless.
Exhaust fixings
Exhaust fixings
Re: Exhaust fixings
Do you have a photo of the hangers you'll need? I might be able to help out following the replacement of all of mine with polybushes.
Re: Exhaust fixings
As for clamps, do you know what size you'll need? 54mm rings a bell. Let me know, got loads here.
Re: Exhaust fixings
Cheers, need them for Saturday morning so probably a motorfactors job.humbucker wrote:As for clamps, do you know what size you'll need? 54mm rings a bell. Let me know, got loads here.
Poly bushed my back box one as kept slipping off its mount.
Re: Exhaust fixings
Well that was simples
Called my local Motorbitz and they can get full set excluding manifold to head gasket for £14 by tomorrow so ordered that, should do for time being and hope it fits the new straight centre pipe
Re: Exhaust fixings
Result. Is that gaskets + clamps?
Re: Exhaust fixings
Yes mate, everything bar the manifold gasketCavalier342 wrote:Result. Is that gaskets + clamps?
