Reinstalling In tank pump
Hi
When putting the tank pump back in does the filter point back towards the other side of the tank or forwards towards the closest side? Or even at a sideways angle? I forgot what way it was pointing when I took it out. You can swivel it 360 degrees on it's mount and it is mounted off centre. There is a pot inside the tank that it goes into so I set it pointing back the way as the pot is a little back from the mount hole. I'm assuming the filter sits right on the bottom of the tank and is actually pressed down a little bit against the base of the tank when you tighten up the bolts; the bottom of the filter is flat on the bottom, and the grilled mesh pick ups round the filter are above this at a small angle so they are not flat on the bottom of the tank.
Thanks
Andrew
Re: Reinstalling In tank pump
Been years since I replaced mine, from what I can marginally remember, the filter on the bottom of the pump is an oval-ish shape, not a circle, I think I had it pointing towards the back of the tank when re-fitting, if you look in the tank, there will be like a plastic housing almost, it'll sit inside that, that's almost like a reserve area, if you will, if it goes in smoothly, then you've done it correctly. I don' t think it should touch the inside of the tank, at least in theory it shouldn't so it doesn't pick up bits of crap at the bottom...
