Cavalier x20xev air intake pipes
Hi all, on the air intake pipe between the air box and the air flow meter there is another pipe coming off the bottom of it. Where does this pipe go to in the car??. Thanks in advance
Re: Cavalier x20xev air intake pipes
Not sure about those engines but it could possibly be a vacuum hose which goes to the throttle body area maybe? Is it a very thin plastic pipe?
I have a funny feeling the pipe your looking at has a funny pipe that comes out the bottom the angles of. after this the pipe does nothing and is blanked. a picture would help
Maybe Rob can look on epc for you
The blanked off pipe is slightly curved and sits behind and to the side of the alternator drivebelt pulley.btcctroy wrote:I have a funny feeling the pipe your looking at has a funny pipe that comes out the bottom the angles of. after this the pipe does nothing and is blanked. a picture would help
It's very close so make sure there's a clearance when you reassemble - my first car's one had a hole worn through it when I got it.
I still don't know what it's for though. Airflow, moisture trap, stash
Looking at TIS, it would appear to go to one of the two stubs for crank case ventilation at the rear of the camshaft cover.
It appears to go to the stub closest to the timing belt end of the engine.
If I'm on the right track it's part no. 5 you're talking about?
http://www.catcar.info/opel/?lang=en&l= ... EwMg%3D%3D
I must admit the rest of the illustration means nothing to me, I've had ecotec for 20 years and have no knowledge of anything in the lower half. A resonator? What's that?
The resonator is an air receiver box intended to reduce air intake noise to the air filter.
Usually mounted low down behind the bumper, below the right headlamp or there-abouts.
If you remember the loud suction noise of the old volvos (240, 760 etc), then you will know what I mean.
I didn't know that.
Another schoolday
Another schoolday
I love the sound of an old Volvo. Brings back happy memories of my childhood. My dad always used to buy brand new 240 estate's. The last one he kept for about 18 years until it wore out. Up till then he had replaced them every 2-3 years.
Hi all thanks for all the help. Im going with it being a capped off pipe to nowhere.
