C20NE fuel pump
Skara
C20NE fuel pump
Post by Skara »
Not long ago I bought a cavalier (C20NE) for spares because I'm planning to put the engine in the other one (C16NZ), the question I wanted to ask some of you that drive the car with C20NE in it, is fuel pump priming when you turn the ignition on ? In my C16NZ I can hear it loud and clear priming every time I turn the ignition on but on the C20NE there is nothing, the pump can't be heard priming nor the relay can be heard and the car starts fine.
Re: C20NE fuel pump
The pump and relay only fire up when the engine revs reach a high enough speed during cranking.
So the noise is probably drowned by the noise of the engine and starter during cranking.
Skara
Re: C20NE fuel pump
Post by Skara »
Oh is that so, so what you are telling me is that on 1.6 the pump is priming on the ignition and on 2.0 the pump is priming on cranking ?
Re: C20NE fuel pump
I am not sure about the multec equipped cars.
It is a long time since I ran a C18NZ, which is more like the C16NZ2.
But the C20NE is on cranking at a quick enough rpm.
Skara
Re: C20NE fuel pump
Post by Skara »
Well the more you know..., thanks for the reply
