Vectra C Front Fuel Feed Pipe leak
Vectron
Post by Vectron »
Hello everyone i'm new here and i have a question how could i fix this fuel feed pipe leak . In my country can't get this hose anymore becouse car is too old it's 2003 year . Maybe temporary fix ideas
thank you all for help
3cav3
Re: Vectra C Front Fuel Feed Pipe leak
Post by 3cav3 »
I would of thought a hydraulic hose supplier could make you up one of those. With the right ends I could swage one up over here no problem.
Vectron
Post by Vectron »
Thank you . I have still question how to fit other side od hose that is just rubber compressed together with metal line hose that lead to the tank . :scratch
Hi
Have you checked here for part number, not sure what engine you have there are loads, part probably should be avaialbe somewhere, I can still get new bits for my 94 cavy. Let us know your engine code or engine size.
https://opel.7zap.com/en/car/z02/g/0/5-1/
Cav1990
Vectron
Post by Vectron »
Hi it's 1.6 16V year 2003 Z16XE engine. Is it possible that is fix from other Vauxhall
That part number looks correct - item1.
Vauxhall No = 13 141 126
Opel No = 58 20 413
It also looks like your photo.
A search online shows possible items in Germany.
Vectron
Post by Vectron »
Thank you very much for that info
vexorg
Post by vexorg »
Which part is leaking?
David
In the parts catalogue image, it is part number 1.
It just happens that Cavalier1990 managed to guess the correct engine type.
Vectron
Post by Vectron »
vexorg wrote: Thu Apr 15, 2021 10:34 am Which part is leaking?
in middle what is in red circle
vexorg
Post by vexorg »
There are a few parts that can leak in that "circle", the connection, the metal pipe, the crimp, the hose....
David
I think that I understand what you are saying Dave,
You mean -
1 - does it need a whole new pipe?
2 - could it simply be loose at a join?
3 - could it be sorted by re-crimping the original crimps?
In these modern times, it is just "the norm" to replace a complete part, rather than look to see if it could be repaired.
vexorg
Post by vexorg »
Yes, but if the part is no longer available, then you need to get a bit more creative and look at fixing it or making it better.
David
Vectron
Post by Vectron »
the previous owner was repairing this pipe himself. He cut the pipe in between and somehow connected it back with a metal interface but it’s pretty badly done. :wall :wall
https://drive.google.com/file/d/1Lcl3FS ... sp=sharing
Here is picture where he cut it and put ducktape . :wall
vexorg
Post by vexorg »
You could probably remake that connection and fix it.
How far does that pipe run? it may run all the way to the rear of the car in one piece if stock.
David
Vectron
Post by Vectron »
this tube is partly rubber from the connection and is then a compressed connection that does not go apart which goes to the aluminum pipe forward under the body to the tank.
https://drive.google.com/file/d/1gnXDOJ ... sp=sharing
chrisp
Post by chrisp »
The flexible pipe on the left of the picture looks newer, so I'd guess that, because it didn't have the crimped-on union required, the previous owner just cut the old pipe and grafted the stub of it and its original union onto the new pipe (but by the looks of it badly!). As said previously you should be able to join the old and new pipes using a suitable piece of copper or steel tubing of an outside diameter that fits the internal diameter of the flexible pipes and a couple of jubilee (worm drive) clips to hold it in place.
vexorg
Post by vexorg »
Or if possible, something like this: https://www.advancedfluidsolutions.co.u ... 1169-p.asp
The serrated edges stop the pipe slipping as they bite into the hose when clamped.
David
You could do what they do on Cavalier fuel lines, and flare the ends.
(Brake pipe style).
Vectron
Post by Vectron »
Robsey wrote: Mon Apr 19, 2021 8:01 pm You could do what they do on Cavalier fuel lines, and flare the ends.
(Brake pipe style).
is there any picture how is look like
Something like the bottom flare below.
So if you go to a hydraulic line maker, you could get them to make a rigid pipe with a flare on each end.
Vectron
Post by Vectron »
Another idea from Opel GT 1900
vexorg
Post by vexorg »
Flaring steel pipes is tough to do on the average flaring tool.
David
Vectron
Post by Vectron »
vexorg wrote: Tue Apr 20, 2021 4:27 pm Flaring steel pipes is tough to do on the average flaring tool.
indeed . I think i try that with fuel filter fit between
