Not sure if this is in the right section of the forum.
Anyway, had this problem on my last cav too. When I try and fill up at the garage the pump clicks off as though the tank is full every litre or so. I try and reposition the nozzle but no joy. Is there any way to sort this?
Problems filling up with petrol
Re: Problems filling up with petrol
the breathers on the neck are blocked, look in the wheelarch you can see the pipes
- tattoodevil
Cheers Gaz. Is it as simple as pulling them off and blowing them through?
mine does that too. the breathers are the 2 smaller pipes?
Probably need to change them or stick something down them.
Yea the smaller pipes.
I will try and get a look at mine probably blocked i expect.
