ECU Reading?
N638HNG
ECU Reading?
Post by N638HNG »
Ive got a problem with my engine managment light coming on :(! Ive been led to beleev it cud be the cam sensor? The light comes on and the rev counter goes crazy nd eventually the car konks, sometimes its ok 4 days tho :roll: ! Ive heard of some way of reading the ecu?, anyone shed some light on this? 95" 2.0 Sri Ecotec! Thanx
Re: ECU Reading?
find the plug on the top right of the engine bay (as you look at the engine) behind the strut, you will find it plugged into a plastic holder
Then follow this guide.
http://www.topbuzz.co.uk/info/fault_cod ... _codes.htm
N638HNG
Re: ECU Reading?
Post by N638HNG »
Thanx mate :cool
dymond123456
Re: ECU Reading?
Post by dymond123456 »
If it is the cam sensor you might want to ensure you buy a quality part (ideally a genuine Siemens) as I've just changed mine twice because first time I bought a cheap after-market part off ebay and it cured nothing, but in gettting and fitting a siemens all is well again. I found a £20 Siemens sensor at vaux-world website (about half the usual price).
