Hey all. My crankshaft position sensor plays up a lot, especially when its cold, which makes the rev gauge read a bit higher than it should. Almost all the time when its cold too, When its ticking over, it can sometimes read 1200-1300rpm when the engine is perfectly idle. Anyways, today, for some reason, i had it in neutral and noticed the needle go totally insane, jump up to well above 2000, approaching 3000 and jump about in between. I was at the lights, so i restarted the engine, and it went back down a bit. Still does play up though. Now, my question is, does this mean it is on its last legs and what would happen if the sensor fails altogether?
Thanks.
Andrei
crankshaft sensor
crankshaft sensor
Re: crankshaft sensor
its not your crank sensor
its your icv needs cleaning and possibly you need a new temp sensor
Oh right. Well i only mentioned the crank sensor because i had fault codes flash up before regarding that, and it had the same issue.
Ok cheers anywho, i'll look into that.
Andrei.
Andrei.
You sometimes get crankshaft sensor as a fault if the engine isnt running when you read the codes
Oh right cool i see. So, does it do it any harm then or not?
