fuel problem i think?
- GsiCav2000
i checked the fuel pump and it seems fine the gauge at the bottom of the pump has a hole in the mesh filter thing! and i checked the swirl pot and everything looks good there! any other ideas???? THANKS CARL
Re: fuel problem i think?
What is the problem your having?
- GsiCav2000
whenever its reading below a quarter of s tank it starts to cut out going round a left hand corner and going up stept hills, though when the fuel light comes on it cuts out going round left and right hand corners and hills?
Youve got a copy tank and its got no baffles, if its an intank pump the return isnt being fed to the pump.
Either that or your tank has clogged breathers, does it do it if you take off your fuel cap?
- GsiCav2000
thanks, ill have a try see if it doe's it! and let you know
- GsiCav2000
fuel problem! petrol tank
i did what you sayed and took off the fuel cap and it doesn't cut out so i drilled a 3mm hole in the fuel cap and put it back on and it cut out again but doesn't cut out with cap off!!!
- GsiCav2000
- GsiCav2000
Re: fuel problem! petrol tank
what the best way to solve that? an ideas? can the breathers be cleaned or anything?
Should be able to clear the breathers aye.
