Fresh oil, coolant, new filters..blah, blah
Even put a new Alternator Drive belt... what a cow of a job...
(Split the off-side engine mount to get the belt out / in).
Anyway, put it all back together...
Turn the key, and the car cranks in a suggish was...but won't start...
Checked the injector, yes fuel getting to throttle body, but not coming from the injector.
Did the good old flash code - gives 19...
So crank signal malfunction - re-checked all my wiring etc... everything fine.
so is it a coincidence that my C.A.S. has just gone belly up.?
I made a point of not trapping, tugging or snagging anything.. so quite cheesed off...
Any ideas, before I spend yet more money on the damn thing
Another thing I noticed...my cam-belt auto tensioner still moves, despite being locked / bolted back absolutely solidly..
yet i tug on the long run of the belt, and the pointer moves to a slack position and stays there ?????
Had the flamin' belt off and on, along with the tensioner about fives times this weekend...
No matter what I do, the tensioner needle still moves to the slack position...??
totally confused
