V6 fueling issue
V6 fueling issue
V6 fuelling problem; came to cav this morning and she will turn, fire then die... had multimeter on electrical connection on top of tank (pump I believe), we have power on ignition position 3, then nothing... she just dies. Assuming because power runs to the pump when firing the relay is fine and I have a nice expensive pump to buy...?
Re: V6 fueling issue
just thouught can anyone check a EPC to check which other vauxhall models used the same fuel pump as the c25xe cavalier? i.e does anyone know if the v6 veccy or omega used the same part?
not pump/relay getting ecu code 145, which i believe is an immobiliser issue.. help please someone must know what to do here
has the key still got the chip in?
Im only tidying the garage so if you wanna ring me and have a brainstorming session feel free
It will use same fuel pump as Calibra. Vectra and Omega are different.
To me sounds more like an electronic fault. I would say immobiliser.
L reg Cav V6 in Lagoon Blue - will be kept and turned back to shape!
L reg Frontera 2.0i 8v in Flame Red - weekend Green Laning toy..
ɯnɹoɟ ɹǝɥʇouɐ ɯoɹɟ slɥʇ ǝloʇs l
yes the tale... starting with what a pratt I am.
I opened the boot and the key came apart and fell in the car... key went back together and car refused to start. The chip was the only bit that landed outside the boot... Emma found it and now the car runs. Pratt.
- Cavyman_130
glad to hear its working right now
