fuel tank
fuel tank
just spotted that my fuel tank is leaking when the car is at a certain angle ....was just wondering would this cause my car to not start as good as one turn of the key and it used to start straight away ...now it takes a few turn overs like its having to pull the petrol threw ? ....ive been told its because the fuel system is pressurised and it will be sucking air threw the leak ..is this true ? btw my car is 94 cav 2.0 ..16v ...thanx
Re: fuel tank
yup, I'd say so.
Re: fuel tank
thanx envoy ...gonna fit a new tank tonite
Re: fuel tank
I'd personally cover it in stone chip first.
- dave's.veccy
Re: fuel tank
Cavalier tanks, regardless of fuel seem to rot around the seems where the two halves of the tank join together
I replaced mine september last year and before i replaced it, i had starting issues, idling issues and just poor running. Once the tank was changed, it pulled better through the gears and had a perfect idle
Re: fuel tank
thanx for the advice again guys fitted the tank ( stonechipped first and problems seem to b sorted ....but while i was on i noticed the fuel pipe is looking abit supect in places ....could anybody tell me wot size pipe should it be fitted with ....2.0 16v ecotec ....some say 6mm some say 8mm ...?
- dave's.veccy
Re: fuel tank
8 mm mate, well thats what the XE uses anyway so i dont think they will be different
Re: fuel tank
aye,dave's.cavy wrote:8 mm mate, well thats what the XE uses anyway so i dont think they will be different
Re: fuel tank
thanx guys 8mm it is then !
