Front srut/hub separation
Cormach
Post by Cormach »
How do you go about taking the hub off the shock on a 1994 cavalier td it seem that the hub is pushed onto the shock rather that
bolted on with this type of setup
Re: Front srut/hub separation
You cant, you change the insert on the shock by undoing the big nut
Cormach
Post by Cormach »
Thanks GAZ so the shock is inside the section the hub is on with the spring on top
yea once youve took the spring off its obvious how it come apart.
bigmitch
Post by bigmitch »
Cormach wrote:How do you go about taking the hub off the shock on a 1994 cavalier td it seem that the hub is pushed onto the shock rather that
I take it you don't have said haynes manual but as gaz said the strut is inside the hub just remove the bolt, but use of spring clamps
would be good idea
Cormach
Post by Cormach »
Thanks lads I had planned to take the hub off to take it to get a new bearing pressed in .but i ill just send it in whole .
On another note is the front strut the same on a saloon and hatch back?
yea both the same.
Cormach
Post by Cormach »
Gaz wrote:yea both the same.
Thanks mate
