I had a small accident with my drive shaft breaking. Anyway i ended up having to replace the ABS sensor because it got broke.
Anyway i have put the new ABS sensor on but i still have the ABS light on. Is there a way of resetting the system ..
Cheers Ryan
ABS LIGHT RESET
Re: ABS LIGHT RESET
Should reset it self when you fitted the new sensor if you fitted the rite type I believe there are at least 2, identified by a 2 letter code on the lead of the sensor.
Re: ABS LIGHT RESET
Yip resets itself when the problems fixed. Is the abs ring in good shape?
Re: ABS LIGHT RESET
Ahh ok must be a faulty sensor cheers chaps !! Were is the best place to find one !
Many Thanks
Ryan
Many Thanks
Ryan
Re: ABS LIGHT RESET
Maybe Vauxhallcarpts.co.uk or autovaux etc
