Gearbox oil change
Post queries regarding Mk3 Cavalier general maintenance and servicing here
Mk3alan
Gearbox oil change
Post by Mk3alan »
I have changed the gearbox oil a couple of times and as we know there is no drain plug, so I have removed the differential cover to release the old oil.
This works OK but obviously requires a new gasket, and the one I bought recently was £12!
So while the cover was off this time I silver soldered a bush into it and fitted the same size drain plug that's fitted to the engine sump (19mm AF)
Looking forward to the next oil change!
Re: Gearbox oil change
Interesting, so it would be like draining the ATF instead of how it usually is.
Mk3alan
Post by Mk3alan »
So has the automatic got a drain plug?
My auto Astra has no drain plug so I had to take the bottom sump cover off - with a gallon of ATF the other side - fun!
Yes, there is a large plug, 19 or 20mm, can't remember, it's facing towards the offside, I was told that was the drain plug and certainly worked when I changed the ATF once on my Cavalier.
Mk3alan
Post by Mk3alan »
These are the images that I couldn't put on from my mobile!
Looks nice mate.
That's a really nice job you've done there.
Looks good!
Very tidy!
Nice idea, but you only get half the oil out. There is a shelf that retains oil below the main gear cluster.
Mk3alan
Post by Mk3alan »
Not sure about that! there seemed to be quite a lot in the bowl I drained it into?
If there is some left at least it will be diluted with the new oil!
