Can someone recommend a set of springs and shock absorbers for my 1.8 hatch. I would like something that would give me a standard SRI look.
Thanks
Springs and shock absorbers
Re: Springs and shock absorbers
SRi springs are approximately 20mm lower than standard springs.
Eibach do -30mm kits, which will probably be the closest thing to the standard SRi look:
http://www.dcperformance.co.uk/uprated/ ... alier.html
As for dampers take your pick. GAZ, Koni and Bilstein are all great.
Set of SRi springs here, removed from a 1991 40k mile car and a brand new pair of GM front shocks to.snowy wrote:Can someone recommend a set of springs and shock absorbers for my 1.8 hatch. I would like something that would give me a standard SRI look.
Thanks
How much would you want?Gray16v wrote:Set of SRi springs here, removed from a 1991 40k mile car and a brand new pair of GM front shocks to.snowy wrote:Can someone recommend a set of springs and shock absorbers for my 1.8 hatch. I would like something that would give me a standard SRI look.
Thanks
Thanks
RepliedGray16v wrote:PM'd
Concur, however with shockers. look at KYB Ultra's if you don't want to spend alot.James McGrath wrote:SRi springs are approximately 20mm lower than standard springs.
