Think that I have sussed out the window closure module now...
I am going to use the relays within the module to short the "closure" wire for the window and roof circuits to earth.
As far as I am aware, when triggered by the alarm, the relays stay energised for about 25 seconds, which is enough for everything to close fully.
Saves blowing any circuit boards as well.
Envoy CDX wrote:
Aye, as I said, I think they've tapped into the switch power hence the fried board.
Yes, you are quite right,
there was a red wire in the switch block, which they had cut off, and then tapped in their own power feed wire to a red/grey wire.
Also, I cleaned my ICV last monday...it was swimming in black oil, but this was quite thin and runny.
After cleaning it all out, I sprayed it with wd40, to ensure that it stayed lubricated, and then blew the excess out with an air-line.
I didn't notice any change at first, however on a long run on the wednesday, it appeared to idle smoother, and also responded better on initial start up...none of the tractor style mis-fire.
Still ain't going to pull the skin off a custard, but the car seems better than it has been for ages. Fun to drive again
