Engine light come on...
NickSRi
Post by NickSRi »
Hi All,
Did a 'Prom' last night... went well...
However the engine warning light has started to appear (very occasionally)
When it does light up its when Ive taken my foot off the accelerator... when a put my foot down again it disapears... Doesnt do this every time...
No real difference in performance, but sometimes it is a little slow (like it has to catch up) on acceleration..Been like that for a while...
Any clues... maybe a good service is due?
Cheers Nick
Re: Engine light come on...
What engine you got again? Could be a MAP sensor issue or something.
NickSRi
Post by NickSRi »
Cavalier342 wrote:What engine you got again? Could be a MAP sensor issue or something.
Sorry.. It's a 1998cc red top 16v
Most likely a sensor, I think the red tops have a MAF sensor rather than a MAP sensor, could be that but also could be other things. Did you manage to flash up the error code?
If it hasn't been serviced in a while, it won't do any harm in doing that. Check over all the plugs and sensors around the engine bay, give them a clean if need be.
NickSRi
Post by NickSRi »
Cavalier342 wrote:Most likely a sensor, I think the red tops have a MAF sensor rather than a MAP sensor, could be that but also could be other things. Did you manage to flash up the error code?
Thanks for your help and your pointers... Will be on to it this weekend :)
Check your error code fault list, paperclip test if you can, this might help before you start dismantling stuff and spend time and money chasing the problem:
viewtopic.php?f=46&t=630
