hi all
this is one of my first posts although i have been on here for some time!
my question is on my 1993 20i gls to replace the 18mm roll bar links, according to the haynes manual do i have to drop the rear edge of the front subframe down to replace the (press on) type links?. or is there an easy way to replace them. thanks in advance for any sugestions shaun
Drop links or roll bar bushes?? The drop links can be changed without subframe hassle as they are on the ends of the bar. To change the anti roll bar bushes that mount to the subframe you need to lower the rear of the subframe as you cannot get to the bolt that holds them in place.
Thank you for your reply.
It is the links not the bushes I was referring to, but will probably have to change the bushes at the same time.
Cheers Shaun.
Links you do from under the wheel arch. Later ones unbolt but the older ones are a plastic ring with a rubber bush liner and are pressed on to the bar. If you have the early ones cut them off and when you fit the replacement cover the ring and bar with washing up liquid and push it on with a twist in a fluid movement without stopping. Once you stop they can be a pig to move again. Do not be tempted to use any other lubrication or you will risk having to cut the new one off and start again.
