hi ive got a hole on the os windscreen pillar which you can see when you open the door and a little bit of the water drain channel thing?? has rotted away anyone had them repaired and rough price
cheers
windscreen pillar hole ? anyone had them repaired
YOU'VE JUST BEEN NOVATAKEN!!!!!
Re: windscreen pillar hole ? anyone had them repaired
I'm sure it can be repaired easy enough. Nobodys gonna know a rough price for a job like that. You will have to take it to a few bodyshops and see what they say. I wouldn't wanna pay more than £100 though, unless the windscreen needs to come out.
if your welding a repair which is the proper way to do it then you'll need the screen out as the heat build up from welding might crack it. i repaired both on a rs1600i escort i had, they were double skinned, for strength i would assume, so i guess the vauxhall ones will be similar.
sean999
sean999
cheers lads a think theres a good lad from a bodyshop comes into work for his mots ill kidnap him and take him to the cav
