curb lights and sunvisor lights not working
Hey guys and gals.... my front door curb lights and main middle light dont work when u pull the light switch and they also dont work with the doors open.. checked fuses all seem fine.. also the sunvisor lights dont work either, however the map lights work fine.. any help would be great cheers all
Re: curb lights and sunvisor lights not working
Silly question but did you check the bulbs? Failing that, pop the lenses off and check the wiring connectors in there.
I havnt checked them thought theres no way they can all of gone..but il check and if it is them iam gonna look a prat hahaCavalier342 wrote:Silly question but did you check the bulbs? Failing that, pop the lenses off and check the wiring connectors in there.
Map lights are feed from an ignition live, middle light & sunvisor lights have a permanent live from 1 of the fuses can't remember which 1 though, so if they are not working got to be a fuse.
thanks ian..ive checked all the fuses and they all seem fine.. fuse 8 is the one thats for the interior lighting and its fine mate..iangsi wrote:Map lights are feed from an ignition live, middle light & sunvisor lights have a permanent live from 1 of the fuses can't remember which 1 though, so if they are not working got to be a fuse.
Have you put a voltage tester to the light terminals? Just to eliminate that.
very good point no i haven't il try that next thanksCavalier342 wrote:Have you put a voltage tester to the light terminals? Just to eliminate that.
