This is where you can discuss any diagnostic queries in relation to the main topic thread, found here...
viewtopic.php?f=70&t=16896&p=171504#p171504
Updated Flash Codes - Discussion Thread
Re: Updated Flash Codes - Discussion Thread
My V6 is throwing up a code 17 on the ABS - RH Front Solenoid ( Relay & Connections )
Is this just an electrical fault?
According to TIS
There are two causes for fault code 17
If the fault is present at all times (not speed dependent):-
So even if not moving.
This is a break or a short to ground of the lead between the solenoid valve for the front right brake circuit and the ABS control unit.
If the fault only appears when the car is moviing off and travels above 3.5mph (6kmh) then it is suspected that:-
There is a short of the winding for the solenoid valve
or
A short circuit to battery voltage of the lead between the solenoid valve and the ABS control unit
So in simple terms - check the wiring or connections to the ABS module.
I am tempted to suggest looking for pin corrosion in the main ABS connector. Between the solenoid valve and control unit.
or
Screen shots sent via whats app
